Libraries policy
Naming Conventions
Libraries in Шаблон:File and Шаблон:File must be separately packaged, in a library-only package, named with the name of the main library concatenated with the major of the library (or soname, see below). These packages should not contain any binaries, which should be in a different package. The packages can contain other files (e.g., documentation or license) provided that these files are installed to location specific to the package (e.g, Шаблон:Pkg may install something to Шаблон:File). The goal is to be able to install Шаблон:Pkg and Шаблон:Pkg on the same system.
First of all, it is fundamental that the source rpms keep the same name without any major number, so that the git repository contains only one branch for each package.
When the distribution must have two versions of the same library at the same time (for example, qt1 and qt2), the sources rpms will be separated so that we can include both versions in the distribution as two different, independently maintained packages.
Here's a generic example: the following happens when the library comes with binaries, config files, or anything else that won't fit in the main library package (where only libraries go) nor in the devel package (where headers and devel libraries go (e.g. .so and .a)).
- Source package:
- foo-2.3.4-4-rosa2012.src.rpm
- Binary packages:
- foo-2.3.4-4-rosa2012.arch.rpm
- libfoo2-2.3.4-4-rosa2012.arch.rpm
- libfoo-devel-2.3.4-4-rosa2012.arch.rpm
If foo-2.3.4-4-rosa2012.src.rpm produces several libraries, then these libraries must be packaged in separate files - libfoo2-2.3.4-4-rosa2012.arch.rpm, libbar2-2.3.4-4-rosa2012.arch.rpm, etc. However, devel files for them can be provided in a single package. Name of such single package may not start with 'lib'; however, it is desired for 32-bit and 64-bit packages to have different names (e.g., foo-devel and foo64-devel). Rationale: -devel packages are not installed on standard end-user installations, so splitting them doesn't affect end-users but would make developers' life more difficult. Distinct names for 32-bit and 64-bit -devel packages allow to install packages for both architectures in the same system.
If upstream name itself starts with 'lib' (e.g., Шаблон:Pkg) then package with binaries can be named as Шаблон:Pkg or Шаблон:Pkg or something similar allowing to distinguish it from the library package.
Naming on x86_64
- Binary packages:
- foo-2.3.4-4-rosa2012.x86_64.rpm
- lib64foo2-2.3.4-4-rosa2012.x86_64.rpm
- lib64foo-devel-2.3.4-4-rosa2012.x86_64.rpm
To handle this complexity, use Шаблон:Macro:
%mklibname
The %mklibname macro is used to generate the library package names:
- %mklibname [-d [-s]] name [[api] major]
- -d - generate a name for a devel package
- -s - generate a name for a static package (to be used together with -d)
- name - the library name (note that if the library name is libfoo, you should enter "foo", not "libfoo")
- major - the major number to be appended into the name (this should not be used with -d, except in packages mentioned in special cases below)
- api - if the library has a SONAME like libfoo-1.2.so.4, api should be set to 1.2 and major to 4. This results in libfoo1.2_4
Example usage:
- %mklibname foo 5 => libfoo5
- %mklibname -d foo => libfoo-devel
- %mklibname -d -s foo => libfoo-static-devel
*.la files
Modern libtool works fine without *la files, so these files are dropped by default by spec-helper during the build process. Several exceptions are known at the moment that are hardcoded in the spec-helper code. If you think you have found one more exception, feel free to contact rpmbuild maintainers.
Special cases
We described the default policy for library packages, however some special cases can happen and must be handled using the brain:
- Remember to always check the soname of the libraries (Шаблон:Cmd), because some sonames include the library version number, for example Шаблон:File. In this case, the package should be named Шаблон:Pkg.
- Packages ending with a number should be handled by putting a "_" before the major, for example Шаблон:Pkg (in this case the soname would be Шаблон:File).
- It is not necessary to split each library in separate packages: if a package contains several libraries, the name would be built from the main library of the package. If there are problems keeping libraries in the same package (e.g. their major may differ), the package should be split.
- When splitting libraries which were previously in a single package, you may need to add Obsoletes/Conflicts "across" the new packages, to hint Urpmi into putting them in the same transaction (ref: libiptc and libiptables splitting)
- If multiple versions of the package are maintained within the distro with different majors, or an expected future release is going to be source-incompatible in a major way (rebuild of concerned pkgs not being enough, and changes required are too big) with the current version (e.g. QT3/QT4/QT5), the devel package name should include the major. In the former case, the devel subpackage of the newest version should generally not contain the major, only the older versions.
- Some applications (e.g., KDE ones) contain dynamic loading modules which are not libraries. Usually these modules are put into the main application subpackage. But sometimes it is better to include the modules in the library package if they are generally required to be installed when using the library (so that every application using the library doesn't have add manual requires on the modules). In general, decisions should be made on on a case-by-case basis. However, if modules are included in the library package, they must be in a versioned directory (e.g. Шаблон:File for a Шаблон:Pkg package) so that installation of multiple versions of the library doesn't break.
Updating a package which is following the old library policy
Change the name of devel packages from Шаблон:Macro to "Шаблон:Macro" (without Шаблон:Macro! though usually with Шаблон:Macro if present) as seen above and add an Шаблон:Macro for the previous name ("Шаблон:Macro" or "Шаблон:Macro", 2 being the major of the obsoleted devel package). Static-devel packages have to be switched to use Шаблон:Macro. If in doubt, do not hesitate to ask in ROSA mailing lists.
Provides and conflicts
At least Шаблон:Macro should be provided by the -devel package. If the original tarball name differs from %name, you should also provide Шаблон:Macro, for compatibility with other RPM-based systems. If multiple versions of the library are maintained within the distro, only the latest shall provide %name-devel. The older versions provided should provide Шаблон:Macro or Шаблон:Macro where applicable. The maintainer may also opt to provide Шаблон:Macro or Шаблон:Macro in the newest package as well, if the next major number raise is excepted to break source-compatibility (see the Special cases above).
It's important to understand that putting a Шаблон:Macro without the version information makes it impossible for later client RPM's to put a version information on dependencies, e.g. "Шаблон:Macro" is NOT enough, please use "Шаблон:Macro".
If multiple versions of the library are maintained within the distro and the exception allowing the use of major in lib -devel package name is used, you have to add Шаблон:Macro with the other devel package if they are not parallel installable. (this is often the case when the major changed, without renaming the headers).
Adding an old-majored version into the distro
If a package is upgraded to have a new major, and it will be noticed that it is not source-compatible with the previous release and the users of the library cannot be straight-forwardly patched to use the new API, the older library should be maintained in parallel with the new one. The creation process follows with the example package "foo", just upgraded to major 3:
- Git copy package "foo" from just before the major 3 update to package "foo2". Also change the Шаблон:Macro to "foo2" and rename the spec file to Шаблон:File.
- Add 2 (the major) to the devel package name, i.e. libfoo2-devel instead of libfoo-devel. This can be achieved by adding the parameter Шаблон:Macro into the Шаблон:Macro call of Шаблон:Macro.
- Modify any provides so that they have the major number in them. E.g. Шаблон:Macro or Шаблон:Macro is fine.
- Add Conflicts: Шаблон:Macro if the package conflicts with the newer devel package.
No changes are needed in the .spec of the newer version.
An example
Here's an example of a specfile for a package with no binary and config files, so only library binary packages are needed. (Note that the spec file is not valid, it is only an example that shows how it works and to highlight the difference with a normal package.
# api is the part of the library name before the .so
%define api 1.2
# major is the part of the library name after the .so
%define major 1
%define libname %mklibname %{name} %{api} %{major}
%define devname %mklibname %{name} -d
#(!) summary for SRPM only
Summary: C++ interface for popular GUI library gtk+
Version: 1.2.4
Release: 1
%description
#Full and generic description of the whole package. (this will be the SRPM
#description only)
#main package (contains .so.[major]. only)
%package -n %{libname}
#(!) summary for main lib RPM only
Summary: Main library for gtkmm
Group: System/Libraries
%description -n %{libname}
This package contains the library needed to run programs dynamically
linked with gtkmm.
%files -n %{libname}
# include the major number (and api if present) in the file list to catch
changes on version upgrade
%{_libdir}/lib-%{api}.so.%{major}*
%package -n %{devname}
Summary: Headers for developing programs that will use Gtk--
Group: Development/GNOME and GTK+
Requires: %{libname} = %{EVRD}
#(!) Not mandatory, since we prefer to use pkgconfig-style dependencies.
# But if the library doesn't have pkgconfig files, this provide is a must
Provides: %{name}-devel = %{EVRD}
%description -n %{devname}
This package contains the headers that programmers will need to develop
applications which will use Gtk--, the C++ interface to the GTK+ (the Gimp
ToolKit) GUI library.
%files -n %{devname}
%{_bindir}/gtkmm-config
%{_includedir}/*.h
%{_libdir}/*.so
