Jump to content
Template Spec Files
Spec file for a program built using GNU Autotools
Summary:	foo
Version:	1.0
Release:	1
License:	foo
Group:		foo
Url:		foo
Source0:	%{name}-%{version}.tar.gz
%description
foo.
%files -f %{name}.lang
%prep
%autosetup -p1
%build
%configure
%make_build
%install
%make_install
%find_lang %{name}
Spec file for a program built using CMake
Summary:	foo
Version:	1.0
Release:	1
License:	foo
Group:		foo
Url:		foo
BuildRequires:  cmake
%description
foo.
%prep
%autosetup -p1
%build
%cmake
%make_build
%install
%make_install -C build
%find_lang %{name}
Spec file for a program written in Qt4 and built using cmake
Summary:	foo
Version:	1.0
Release:	1
License:	foo
Group:		foo
Url:		foo
BuildRequires:  qt4-devel
%description
foo.
%prep
%autosetup -p1
%build
%cmake_qt4
%make_build
%install
%find_lang %{name}
Spec file for a program written in Qt5 and built using cmake
Summary:	foo
Version:	1.0
Release:	1
License:	foo
Group:		foo
Url:		foo
BuildRequires:  qt5-devel
%description
foo.
%prep
%autosetup -p1
%build
%cmake_qt5
%make_build
%install
%find_lang %{name}
Spec file for a program built using Meson
Summary:	foo
Version:	1.0
Release:	1
License:	foo
Group:		foo
Url:		foo
BuildRequires:	meson
%description
foo.
%prep
%autosetup -p1
%build
%meson
%meson_build
%install
%meson_install
%find_lang %{name}
Spec file for a program built using Perl/Makefile.PL
%define upstream_name foo
%define upstream_version 1.0
Summary:	foo
Version:	%perl_convert_version %{upstream_version}
Release:	1
License:	foo
Group:		Development/Perl
Url:		foo
Source0:	%{upstream_name}-%{upstream_version}.tar.gz
BuildRequires:	perl-devel
BuildRequires:	perl(ExtUtils::MakeMaker)
%description
foo.
%files
%prep
%autosetup -p1 -n %{upstream_name}-%{upstream_version}
%build
perl Makefile.PL INSTALLDIRS=vendor
%make_build
%check
make test
%install
%make_install
Spec file for a program built using Perl/Build.PL
Summary:	foo
Release:	1
License:	foo
Url:		foo
BuildRequires:	perl(Module::Build)
%description
foo.
%files
%prep
%build
perl Build.PL installdirs=vendor
./Build CFLAGS="%{optflags}"
%check
./Build test
%install
./Build install destdir=%{buildroot}
Spec file for a Python module
Spec file to build python3 module with setup.py
python-mymodule.spec:
%define pypi_name mymodule
Summary:	Example module
Version:	1.0
Release:	1
License:	GPL
Group:		Development/Python
Url:		http://mypage.org/mymodule
Source0:	%{pypi_name}-%{version}.tar.gz
#if source available on pypi.org uncoment next line, and remove line Source0: above
#Source0:	%pypi_source
BuildRequires:	pkgconfig(python3)
%define _description %{expand:
Text about
example Python module
%description
%{_description}
%package -n python3-%{pypi_name}
Summary:	%{summary}
%description -n python3-%{pypi_name}
%{_description}
%files -n python3-%{pypi_name}
# for files in /usr/lib64/python3.8/site-packages
%{python3_sitearch}/*
%{python3_sitearch}/%{pypi_name}-%{version}-py*.egg-info
# for files in /usr/lib/python3.8/site-packages uncomment next lines
#%%{python3_sitelib}/*
#%%{python3_sitelib}/%{pypi_name}-%{version}-py*.egg-info
%prep
%autosetup -p1 -n %{pypi_name}-%{version}
%build
%py3_build
%install
%py3_install
# uncomment for fix rpmlint error "set python3 shebang"
#%%py3_shebang_fix
%check
%pytest
Spec file to build python3 module with pyproject.toml
Version:	1.0
Release:	1
License:	GPL
# if source not available on pypi.org uncomment line below and comment Source0 upper
#Source0:	%{pypi_name}-%{version}.tar.gz
BuildRequires:	pyproject-rpm-macros
# for %%check if needed
BuildRequires:	python3egg(pytest)
Text about
%description
%{_description}
Summary:	%{summary}
%{_description}
%files -n python3-%{pypi_name} -f %{pyproject_files}
%license LICENSE
%doc README*
%prep
# for autoinstall BuildRequires
%generate_buildrequires
%pyproject_buildrequires -r
%build
%pyproject_wheel
%install
%pyproject_install
%pyproject_save_files %{pypi_name}
#%%py3_shebang_fix
%check
%pytest
Spec file to build python2 module (ROSA <= 2016.1)
%define module	mymodule
Version:	1.0
Release:	1
License:	Apache License
Source0:	%{module}-%{version}.tar.gz
BuildRequires:	pkgconfig(python2)
%description
Example Python module.
%files
%doc *.txt
%{python2_sitearch}/*
%prep
%setup -q
%apply_patches
%build
%py2_build
%install
%py2_install
Spec file to build python2 module (ROSA >= 2021.1)
Version:	1.0
Release:	1
Text about
%description
%{_description}
%package -n python2-%{pypi_name}
Summary:	%{summary}
%description -n python2-%{pypi_name}
%{_description}
%files -n python2-%{pypi_name}
%prep
%build
%py2_build
%install
%py2_install
Spec file for both python2 and python3 modules, ROSA >= 2021.1
Version:	1.0
Release:	1
Text about
%description
%{_description}
Summary:	Example python2 module
%py2_migration_meta python-%{pypi_name}
%{_description}
Summary:	Example python3 module
%{_description}
%prep
%build
%py2_build
%py3_build
%install
%py2_install
%py3_install
See also: %py2_migration_info
Spec file for a Library
%define major 1
%define libname %mklibname %{name} %{major}
%define devname %mklibname %{name} -d
# Usually we don't need to build static library
# But let's add it to spec template anyway
%define sdevname %mklibname %{name} -d -s
Summary:	foo
Version:	1.0
Release:	1
License:	foo
Group:		System/Libraries
Url:		foo
%description
foo.
%package -n %{libname}
Summary:	%{name} shared library
%description -n %{libname}
%{name} shared library.
%files -n %{libname}
%{_libdir}/lib%{name}.so.%{major}*
%package -n %{devname}
Summary:	%{name} development files
Group:		Development/Other
Requires:	%{libname} = %{EVRD}
Provides:	%{name}-devel = %{EVRD}
%description -n %{devname}
%{name} development files.
%files -n %{devname}
%{_includedir}/*.h
%{_libdir}/*.so
%package -n %{sdevname}
Summary:	%{name} development files (static library)
Requires:	%{devname} = %{EVRD}
Provides:	%{name}-static-devel = %{EVRD}
%description -n %{sdevname}
%{name} development files (static library).
%files -n %{sdevname}
%{_libdir}/*.a
%prep
%autosetup -p1
%build
%configure
%make_build
%install
%make_install
See also: Libraries policy
Spec file for a Node.js module
%define oname foo
Summary:        foo
Version:        1.0
Release:        1
License:        foo
Url:            foo
Source0:        %{oname}-%{version}.tgz
BuildRequires:  nodejs-packaging
BuildArch:      noarch
%description
%{summary}.
%files
%doc LICENSE
%{nodejs_sitelib}/%{oname}
%prep
%autosetup -p1 -n package
rm -rf node_modules
%build
%install
mkdir -p %{buildroot}/%{nodejs_sitelib}/%{oname}
cp -r package.json index.js %{buildroot}/%{nodejs_sitelib}/%{oname}
%nodejs_symlink_deps
Spec file for a Ruby Gem (ROSA >= 2021.1)
%define gem_name  foo
Summary:        Foo
Version:        1.0
Release:        1
Group:          Development/Ruby
License:        GPLv2+ or Ruby
URL:            foo
Source0:        %{gem_name}-%{version}.gem
BuildRequires:  rubygems-devel
BuildArch:      noarch
%description
%{summary}.
%files
%dir %{gem_instdir}
%license %{gem_instdir}/LICENSE.txt
%{gem_libdir}
%exclude %{gem_cache}
%{gem_spec}
%package        doc
Summary:        Documentation for %{name}
Group:          Books/Computer books
Requires:       %{name} = %{EVRD}
%description    doc
Documents, RDoc & RI documentation for %{name}.
%files doc
%doc %{gem_docdir}
%doc %{gem_instdir}/CHANGELOG.md
%{gem_instdir}/Gemfile
%doc %{gem_instdir}/README.md
%doc %{gem_instdir}/SECURITY.md
%prep
%autosetup -p1 -n %{gem_name}-%{version}
%build
%gem_build
%install
%gem_install
mkdir -p %{buildroot}%{gem_dir}
cp -a .%{gem_dir}/* \
        %{buildroot}%{gem_dir}/
cp ../%{gem_name}-%{version}.gemspec %{buildroot}%{gem_dir}/specifications
Spec file for a Ruby Gem (ROSA <= 2016.1)
%define rbname  foo
Summary:        Foo
Version:        1.0
Release:        1
URL:            foo
Source0:        %{rbname}-%{version}.gem
BuildArch:      noarch
%description
%{summary}.
%files
%{ruby_gemdir}/gems/%{rbname}-%{version}
%{ruby_gemdir}/specifications/%{rbname}-%{version}.gemspec
%package        doc
%description    doc
%files doc
%{ruby_gemdir}/doc/%{rbname}-%{version}
%prep
%setup -q
%apply_patches
%build
%gem_build
%install
%gem_install
Spec file for a Haskell Library
%define _disable_ld_no_undefined 1
%global debug_package %{nil}
%global pkg_name Foo
%global pkgver %{pkg_name}-%{version}
Summary:	foo
Version:	1.0
Release:	1
License:	BSD
Group:		Development/Haskell
Url:            https://hackage.haskell.org/package/%{pkg_name}
Source0:        https://hackage.haskell.org/package/%{pkgver}/%{pkgver}.tar.gz
BuildRequires:  ghc-devel
BuildRequires:  ghc-prof
BuildRequires:  ghc-rpm-macros
%description
%{summary}.
%files -f %{name}.files
%license LICENSE
%package devel
Summary:        %{summary}
Provides:       %{name}-static = %{EVRD}
Provides:       %{name}-static%{?_isa} = %{EVRD}
%if %{defined ghc_version}
Requires:       ghc = %{ghc_version}
%endif
Requires:       %{name}%{?_isa} = %{EVRD}
%description devel
This package provides the Haskell %{pkg_name} library development files.
%files devel -f %{name}-devel.files
%if %{with haddock}
%package doc
Summary:        Haskell %{pkg_name} library documentation
BuildArch:      noarch
%description doc
This package provides the Haskell %{pkg_name} library documentation.
%files doc -f %{name}-doc.files
%license LICENSE
%endif
%if %{with ghc_prof}
%package prof
Summary:        Haskell %{pkg_name} profiling library
Requires:       %{name}-devel%{?_isa} = %{EVRD}
Supplements:    (%{name}-devel and ghc-prof)
%description prof
This package provides the Haskell %{pkg_name} profiling library.
%files prof -f %{name}-prof.files
%endif
%prep
%autosetup -p1 -n %{pkgver}
%build
%ghc_lib_build
%install
%ghc_lib_install
Spec file when building a git snapshot
%define commit 0123456789abcdef101112131415161718191a1b
%define commit_short %(echo %{commit} | head -c6)
Summary:	foo
Version:	foo
Release:	0.git%{commit_short}.1
License:	foo
Group:		foo
Url:		foo
Source0:	%{name}-%{commit}.tar.gz
%description
foo.
%files
%prep
%autosetup -p1 -n %{name}-%{commit}
%build
%install
Source example for Github, Gogs, Gitea, Forgejo:
Source0:	https://github.com/owner/repo/archive/%{commit}.tar.gz?/%{name}-%{commit}.tar.gz
Source example for Gitlab, MosHub:
Source0:	https://gitlab.com/owner/repo/-/archive/%{commit}/%{name}-%{commit}.tar.gz
Source example for GitWeb:
Source0:	https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/snapshot/%{commit}.tar.gz
Source example for GitVerse:
Source0:	https://gitverse.ru/api/repos/owner/repo/archive/%{commit}.tar.gz?/%{name}-%{commit}.tar.gz
To update such a package:
  1. Change Version to the latest tagged release
  2. Change commit hash in the spec
  3. Change the first number of the Release tag to "0" if the Version was incrimented, otherwise incriment that first number
  4. Change the last number in the Release to 1
  5. Run:
rm -fv .abf.yml
spectool -g *.spec
abf put
If upstream has no tagged versions at all, use "Version: 0", example: [1]
Spec file for a golang
# use bundled golang modules (from Source1)
%global gomodulesmode GO111MODULE=off
# see Source0
%global goipath github.com/foo/bar
Summary:	foo
Version:	1.0
Release:	1
License:	MIT
Url:		http://github.com/foo/bar
Source0:	http://github.com/foo/bar/archive/refs/tags/v%{version}.tar.gz?/%{name}-%{version}.tar.gz
# unpack source and run 'go mod vendor' in source dir, tar.gz 'vendor' dir
Source1:	%{name}-vendor-%{version}.tar.gz
BuildRequires:	golang
%gometa
%description
%{summary}.
%files
%{_bindir}/%{name}
%prep
%goprep
# prepare vendored modules
tar -xf %{SOURCE1}
cp -r ./vendor/* _build/src/
%build
%gobuild -o %{gobuilddir}/bin/%{name} %{goipath}/cmd/%{name}
%install
install -d %{buildroot}%{_bindir}
install -Dm0755 %{gobuilddir}/bin/%{name} %{buildroot}%{_bindir}
See also: [2]
