Template Spec Files
Материал из ROSA Wiki
Spec file for a program built using GNU Autotools
Summary: foo
Version: 1.0
Release: 1
License: foo
Group: foo
Url: foo
Source0: %{name}-%{version}.tar.gz
%description
foo.
%files -f %{name}.lang
%prep
%autosetup -p1
%build
%configure
%make_build
%install
%make_install
%find_lang %{name}
Spec file for a program built using CMake
Summary: foo
Version: 1.0
Release: 1
License: foo
Group: foo
Url: foo
BuildRequires: cmake
%description
foo.
%prep
%autosetup -p1
%build
%cmake
%make_build
%install
%make_install -C build
%find_lang %{name}
Spec file for a program written in Qt4 and built using cmake
Summary: foo
Version: 1.0
Release: 1
License: foo
Group: foo
Url: foo
BuildRequires: qt4-devel
%description
foo.
%prep
%autosetup -p1
%build
%cmake_qt4
%make_build
%install
%find_lang %{name}
Spec file for a program written in Qt5 and built using cmake
Summary: foo
Version: 1.0
Release: 1
License: foo
Group: foo
Url: foo
BuildRequires: qt5-devel
%description
foo.
%prep
%autosetup -p1
%build
%cmake_qt5
%make_build
%install
%find_lang %{name}
Spec file for a program built using Meson
Summary: foo
Version: 1.0
Release: 1
License: foo
Group: foo
Url: foo
BuildRequires: meson
%description
foo.
%prep
%autosetup -p1
%build
%meson
%meson_build
%install
%meson_install
%find_lang %{name}
Spec file for a program built using Perl/Makefile.PL
%define upstream_name foo
%define upstream_version 1.0
Summary: foo
Version: %perl_convert_version %{upstream_version}
Release: 1
License: foo
Group: foo
Url: foo
Source0: %{upstream_name}-%{upstream_version}.tar.gz
BuildRequires: perl-devel
BuildRequires: perl(ExtUtils::MakeMaker)
%description
foo.
%files
%prep
%autosetup -p1 -n %{upstream_name}-%{upstream_version}
%build
perl Makefile.PL INSTALLDIRS=vendor
%make_build
%check
make test
%install
%make_install
Spec file for a program built using Perl/Build.PL
Summary: foo
Release: 1
License: foo
Group: foo
Url: foo
BuildRequires: perl(Module::Build)
%description
foo.
%files
%prep
%build
perl Build.PL installdirs=vendor
./Build CFLAGS="%{optflags}"
%check
./Build test
%install
./Build install destdir=%{buildroot}
Spec file for a Python module
Spec file to build python3 module with setup.py
python-mymodule.spec:
%define pypi_name mymodule
Summary: Example module
Version: 1.0
Release: 1
License: GPL
Group: Development/Python
Url: http://mypage.org/mymodule
Source0: %{pypi_name}-%{version}.tar.gz
#if source available on pypi.org uncoment next line, and remove line Source0: above
#Source0: %pypi_source
BuildRequires: pkgconfig(python3)
%define _description \
Text about \
example Python module
%description
%{_description}
%package -n python3-%{pypi_name}
Summary: %{summary}
%description -n python3-%{pypi_name}
%{_description}
%files -n python3-%{pypi_name}
# for files in /usr/lib64/python3.8/site-packages
%{python3_sitearch}/*
%{python3_sitearch}/%{pypi_name}-%{version}-py*.egg-info
# for files in /usr/lib/python3.8/site-packages uncomment next lines
#%%{python3_sitelib}/*
#%%{python3_sitelib}/%{pypi_name}-%{version}-py*.egg-info
%prep
%autosetup -p1
%build
%py3_build
%install
%py3_install
# uncomment for fix rpmlint error "set python3 shebang"
#%%py3_shebang_fix
%check
%pytest
Spec file to build python3 module with pyproject.toml
Version: 1.0
Release: 1
License: GPL
# if source not available on pypi.org uncomment line below and comment Source0 upper
#Source0: %{pypi_name}-%{version}.tar.gz
BuildRequires: pyproject-rpm-macros
# for %%check if needed
BuildRequires: python3egg(pytest)
Text about \
%description
%{_description}
Summary: %{summary}
%{_description}
%files -n python3-%{pypi_name} -f %{pyproject_files}
%license LICENSE
%doc README*
%prep
%autosetup -p1 -n %{pypi_name}-%{version}
# for autoinstall BuildRequires
%generate_buildrequires
%pyproject_buildrequires -r
%build
%pyproject_wheel
%install
%pyproject_install
%pyproject_save_files %{pypi_name}
#%%py3_shebang_fix
%check
%pytest
<pre>
== Spec file to build python2 module (ROSA <= 2016.1) ==
<pre>
%define module mymodule
Version: 1.0
Release: 1
License: Apache License
Source0: %{module}-%{version}.tar.gz
BuildRequires: pkgconfig(python2)
%description
Example Python module.
%files
%doc *.txt
%{python2_sitearch}/*
%prep
%setup -q
%apply_patches
%build
%py2_build
%install
%py2_install
Spec file to build python2 module (ROSA >= 2021.1)
Version: 1.0
Release: 1
Text about \
%description
%{_description}
%package -n python2-%{pypi_name}
Summary: %{summary}
%description -n python2-%{pypi_name}
%{_description}
%files -n python2-%{pypi_name}
%prep
%autosetup -p1
%build
%py2_build
%install
%py2_install
Spec file for both python2 and python3 modules, ROSA >= 2021.1
Version: 1.0
Release: 1
Text about \
%description
%{_description}
Summary: Example python2 module
%py2_migration_meta python-%{pypi_name}
%{_description}
Summary: Example python3 module
%{_description}
%prep
%autosetup -p1
%build
%py2_build
%py3_build
%install
%py2_install
%py3_install
See also: %py2_migration_info
Spec file for a Library
%define major 1
%define libname %mklibname %{name} %{major}
%define devname %mklibname %{name} -d
# Usually we don't need to build static library
# But let's add it to spec template anyway
%define sdevname %mklibname %{name} -d -s
Summary: foo
Version: 1.0
Release: 1
License: foo
Group: foo
Url: foo
%description
foo.
%package -n %{libname}
Summary: %{name} shared library
Group: System/Libraries
%description -n %{libname}
%{name} shared library.
%files -n %{libname}
%{_libdir}/lib%{name}.so.%{major}*
%package -n %{devname}
Summary: %{name} development files
Group: Development/Other
Requires: %{libname} = %{EVRD}
Provides: %{name}-devel = %{EVRD}
%description -n %{devname}
%{name} development files.
%files -n %{devname}
%{_includedir}/*.h
%{_libdir}/*.so
%package -n %{sdevname}
Summary: %{name} development files (static library)
Requires: %{devname} = %{EVRD}
Provides: %{name}-static-devel = %{EVRD}
%description -n %{sdevname}
%{name} development files (static library).
%files -n %{sdevname}
%{_libdir}/*.a
%prep
%autosetup -p1
%build
%configure
%make_build
%install
%make_install
See also: Libraries policy
Spec file for a Node.js module
%define oname foo
Summary: foo
Version: 1.0
Release: 1
License: foo
Url: foo
Source0: %{oname}-%{version}.tgz
BuildRequires: nodejs-packaging
BuildArch: noarch
%description
%{summary}.
%files
%doc LICENSE
%{nodejs_sitelib}/%{oname}
%prep
%autosetup -p1 -n package
rm -rf node_modules
%build
%install
mkdir -p %{buildroot}/%{nodejs_sitelib}/%{oname}
cp -r package.json index.js %{buildroot}/%{nodejs_sitelib}/%{oname}
%nodejs_symlink_deps
Spec file for a Ruby Gem (ROSA >= 2021.1)
%define gem_name foo
Summary: Foo
Version: 1.0
Release: 1
Group: Development/Ruby
License: GPLv2+ or Ruby
URL: foo
Source0: %{gem_name}-%{version}.gem
BuildRequires: rubygems-devel
BuildArch: noarch
%description
%{summary}.
%files
%dir %{gem_instdir}
%license %{gem_instdir}/LICENSE.txt
%{gem_libdir}
%exclude %{gem_cache}
%{gem_spec}
%package doc
Summary: Documentation for %{name}
Group: Books/Computer books
Requires: %{name} = %{EVRD}
%description doc
Documents, RDoc & RI documentation for %{name}.
%files doc
%doc %{gem_docdir}
%doc %{gem_instdir}/CHANGELOG.md
%{gem_instdir}/Gemfile
%doc %{gem_instdir}/README.md
%doc %{gem_instdir}/SECURITY.md
%prep
%autosetup -p1 -n %{gem_name}-%{version}
%build
%gem_build
%install
%gem_install
mkdir -p %{buildroot}%{gem_dir}
cp -a .%{gem_dir}/* \
%{buildroot}%{gem_dir}/
cp ../%{gem_name}-%{version}.gemspec %{buildroot}%{gem_dir}/specifications
Spec file for a Ruby Gem (ROSA <= 2016.1)
%define rbname foo
Summary: Foo
Version: 1.0
Release: 1
URL: foo
Source0: %{rbname}-%{version}.gem
BuildArch: noarch
%description
%{summary}.
%files
%{ruby_gemdir}/gems/%{rbname}-%{version}
%{ruby_gemdir}/specifications/%{rbname}-%{version}.gemspec
%package doc
%description doc
%files doc
%{ruby_gemdir}/doc/%{rbname}-%{version}
%prep
%setup -q
%apply_patches
%build
%gem_build
%install
%gem_install
Spec file for a Haskell Library
%define _disable_ld_no_undefined 1
%global debug_package %{nil}
%global pkg_name Foo
%global pkgver %{pkg_name}-%{version}
Summary: foo
Version: 1.0
Release: 1
License: BSD
Group: Development/Haskell
Url: https://hackage.haskell.org/package/%{pkg_name}
Source0: https://hackage.haskell.org/package/%{pkgver}/%{pkgver}.tar.gz
BuildRequires: ghc-devel
BuildRequires: ghc-prof
BuildRequires: ghc-rpm-macros
%description
%{summary}.
%files -f %{name}.files
%license LICENSE
%package devel
Summary: %{summary}
Provides: %{name}-static = %{EVRD}
Provides: %{name}-static%{?_isa} = %{EVRD}
%if %{defined ghc_version}
Requires: ghc = %{ghc_version}
%endif
Requires: %{name}%{?_isa} = %{EVRD}
%description devel
This package provides the Haskell %{pkg_name} library development files.
%files devel -f %{name}-devel.files
%if %{with haddock}
%package doc
Summary: Haskell %{pkg_name} library documentation
BuildArch: noarch
%description doc
This package provides the Haskell %{pkg_name} library documentation.
%files doc -f %{name}-doc.files
%license LICENSE
%endif
%if %{with ghc_prof}
%package prof
Summary: Haskell %{pkg_name} profiling library
Requires: %{name}-devel%{?_isa} = %{EVRD}
Supplements: (%{name}-devel and ghc-prof)
%description prof
This package provides the Haskell %{pkg_name} profiling library.
%files prof -f %{name}-prof.files
%endif
%prep
%autosetup -p1 -n %{pkgver}
%build
%ghc_lib_build
%install
%ghc_lib_install
Spec file when building a git snapshot
%define commit 0123456789abcdef101112131415161718191a1b
%define commit_short %(echo %{commit} | head -c6)
Summary: foo
Version: foo
Release: 0.git%{commit_short}.1
License: foo
Group: foo
Url: foo
Source0: %{name}-%{commit}.tar.gz
%description
foo.
%files
%prep
%autosetup -p1 -n %{name}-%{commit}
%build
%install
Source example for Github, Gogs, Gitea, Forgejo:
Source0: https://github.com/owner/repo/archive/%{commit}.tar.gz?/%{name}-%{commit}.tar.gz
Source example for Gitlab, MosHub:
Source0: https://gitlab.com/owner/repo/-/archive/%{commit}/%{name}-%{commit}.tar.gz
Source example for GitWeb:
Source0: https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/snapshot/%{commit}.tar.gz
Source example for GitVerse:
Source0: https://gitverse.ru/api/repos/owner/repo/archive/%{commit}.tar.gz?/%{name}-%{commit}.tar.gz
To update such a package:
- Change Version to the latest tagged release
- Change commit hash in the spec
- Change the first number of the Release tag to "0" if the Version was incrimented, otherwise incriment that first number
- Change the last number in the Release to 1
- Run:
rm -fv .abf.yml spectool -g *.spec abf put
If upstream has no tagged versions at all, use "Version: 0", example: [1]
Spec file for a golang
# use bundled golang modules (from Source1)
%global gomodulesmode GO111MODULE=off
# see Source0
%global goipath github.com/foo/bar
Summary: foo
Version: 1.0
Release: 1
License: MIT
Url: http://github.com/foo/bar
Source0: http://github.com/foo/bar/archive/refs/tags/v%{version}.tar.gz?/%{name}-%{version}.tar.gz
# unpack source and run 'go mod vendor' in source dir, tar.gz 'vendor' dir
Source1: vendor.tar.gz
BuildRequires: golang
%gometa
%description
%{summary}.
%files
%{_bindir}/%{name}
%prep
%goprep
# prepare vendored modules
tar -xf %{SOURCE2}
cp -r ./vendor/* _build/src/
%build
%gobuild -o %{gobuilddir}/bin/%{name} %{goipath}/cmd/%{name}
%install
install -d %{buildroot}%{_bindir}
install -Dm0755 %{gobuilddir}/bin/%{name} %{buildroot}%{_bindir}
See also: [2]
